[postgis-devel] [PostGIS] #571: TRIANGLE fails crash me test
PostGIS trac at osgeo.org
Tue Aug 17 11:27:53 PDT 2010
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by colivier):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Regina,
 Thanks for the report !
 Commited a fix as r5842
 Result look good:
 foo=# SELECT ST_AsEWKT(ST_Affine(ST_GeomFromEWKT(
 'TRIANGLE ((
 0 0,
 0 9,
 9 0,
 0 0
 ))') , 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5, 0.5));
               st_asewkt
  TRIANGLE((0.5 0.5,5 5,5 5,0.5 0.5))
 (1 row)
 'POLYGON ((
 0 0,
 0 9,
 9 0,
 0 0
              st_asewkt
  POLYGON((0.5 0.5,5 5,5 5,0.5 0.5))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/571#comment:2>
