[postgis-devel] [PostGIS] #571: TRIANGLE and TIN fails crash me test (was: TRIANGLE fails crash me test)
trac at osgeo.org
Tue Aug 17 14:16:58 PDT 2010
Reporter: robe | Owner: colivier
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
More hotspots
SELECT ST_Boundary(ST_GeomFromEWKT(
'TRIANGLE ((
0 0,
0 9,
9 0,
0 0
SELECT ST_IsValid(ST_GeomFromEWKT(
'TRIANGLE ((
0 0,
0 9,
9 0,
0 0
SELECT ST_IsValid(ST_GeomFromEWKT('TIN (((
0 0 0,
0 0 1,
0 1 0,
0 0 0
0 0 0,
0 1 0,
1 1 0,
0 0 0
I suspect pretty much any GEOS function will crash the server when
confronted with TRIANGLE or TIN.
Probably related to #570.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/571#comment:3>
