[postgis-devel] cunit failures
Paul Ramsey pramsey at opengeo.org
Tue Dec 14 12:31:14 PST 2010
Fixes committed, and I set cu_tester to return the number of tests
failed, so a non-zero result on any tests failing.
P
On Tue, Dec 14, 2010 at 11:00 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Apologies, I must have accidentally run the KML tests against the old
> library and got zero failures.
> Working on this
> P
> On Tue, Dec 14, 2010 at 9:34 AM, strk <strk at keybit.net> wrote:
>> Run Summary: Type      Total     Ran  Passed  Failed
>>             suites       17      17     n/a       0
>>             tests       142     142     138       4
>>             asserts    1217    1217    1194      23
>> Is it intentional for 'make check' to return 0 (success)
>> even in presence of those failures ?
>> This is r6380, and failures seem related to kml.
>> Yes I did ...
>> make clean && autogen && ./configure && make clean && make
>> (did anyone look at my new GNUMakefile, btw?)
>> --strk;
>>  ()   Free GIS & Flash consultant/developer
>>  /\   http://strk.keybit.net/services.html
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
