[postgis-devel] [PostGIS] #713: new GNUMake.in is broken on mingW
PostGIS trac at osgeo.org
Wed Dec 15 10:28:43 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw    |
 Sandro,
 what is this GNUMake.in  supposed to do
 All I see on my mingW screen is this:
 Using GNU make found at /bin/make
 make[600]: Entering directory `/c/projects/PostGIS/trunk'
 make[601]: Entering directory `/c/projects/PostGIS/trunk'
 make[602]: Entering directory `/c/projects/PostGIS/trunk'
 make[603]: Entering directory `/c/projects/PostGIS/trunk'
 make[604]: Entering directory `/c/projects/PostGIS/trunk'
 make[605]: Entering directory `/c/projects/PostGIS/trunk'
 make[606]: Entering directory `/c/projects/PostGIS/trunk'
 make[607]: Entering directory `/c/projects/PostGIS/trunk'
 make[608]: Entering directory `/c/projects/PostGIS/trunk'
 make[609]: Entering directory `/c/projects/PostGIS/trunk'
 make[610]: Entering directory `/c/projects/PostGIS/trunk'
 make[611]: Entering directory `/c/projects/PostGIS/trunk'
 make[612]: Entering directory `/c/projects/PostGIS/trunk'
 make[613]: Entering directory `/c/projects/PostGIS/trunk'
 make[614]: Entering directory `/c/projects/PostGIS/trunk'
 make[615]: Entering directory `/c/projects/PostGIS/trunk'
 make[616]: Entering directory `/c/projects/PostGIS/trunk'
 make[617]: Entering directory `/c/projects/PostGIS/trunk'
 make[618]: Entering directory `/c/projects/PostGIS/trunk'
 make[619]: Entering directory `/c/projects/PostGIS/trunk'
 make[620]: Entering directory `/c/projects/PostGIS/trunk'
 make[621]: Entering directory `/c/projects/PostGIS/trunk'
 make[622]: Entering directory `/c/projects/PostGIS/trunk'
 make[623]: Entering directory `/c/projects/PostGIS/trunk'
 make[624]: Entering directory `/c/projects/PostGIS/trunk'
 make[625]: Entering directory `/c/projects/PostGIS/trunk'
 make[626]: Entering directory `/c/projects/PostGIS/trunk'
 make[627]: Entering directory `/c/projects/PostGIS/trunk'
 make[628]: Entering directory `/c/projects/PostGIS/trunk'
 make[629]: Entering directory `/c/projects/PostGIS/trunk'
 make[630]: Entering directory `/c/projects/PostGIS/trunk'
 make[631]: Entering directory `/c/projects/PostGIS/trunk'
 make[632]: Entering directory `/c/projects/PostGIS/trunk'
 make[633]: Entering directory `/c/projects/PostGIS/trunk'
 make[634]: Entering directory `/c/projects/PostGIS/trunk'
 make[635]: Entering directory `/c/projects/PostGIS/trunk'
 make[636]: Entering directory `/c/projects/PostGIS/trunk'
 make[637]: Entering directory `/c/projects/PostGIS/trunk'
 make[638]: Entering directory `/c/projects/PostGIS/trunk'
 make[639]: Entering directory `/c/projects/PostGIS/trunk'
 make[640]: Entering directory `/c/projects/PostGIS/trunk'
 make[641]: Entering directory `/c/projects/PostGIS/trunk'
 make[642]: Entering directory `/c/projects/PostGIS/trunk'
 make[643]: Entering directory `/c/projects/PostGIS/trunk'
 make[644]: Entering directory `/c/projects/PostGIS/trunk'
 make[645]: Entering directory `/c/projects/PostGIS/trunk'
 make[646]: Entering directory `/c/projects/PostGIS/trunk'
 make[647]: Entering directory `/c/projects/PostGIS/trunk'
 make[648]: Entering directory `/c/projects/PostGIS/trunk'
 make[649]: Entering directory `/c/projects/PostGIS/trunk'
 make[650]: Entering directory `/c/projects/PostGIS/trunk'
 make[651]: Entering directory `/c/projects/PostGIS/trunk'
 make[652]: Entering directory `/c/projects/PostGIS/trunk'
 make[653]: Entering directory `/c/projects/PostGIS/trunk'
 make[654]: Entering directory `/c/projects/PostGIS/trunk'
 make[655]: Entering directory `/c/projects/PostGIS/trunk'
 make[656]: Entering directory `/c/projects/PostGIS/trunk'
 make[657]: Entering directory `/c/projects/PostGIS/trunk'
 make[658]: Entering directory `/c/projects/PostGIS/trunk'
 make[659]: Entering directory `/c/projects/PostGIS/trunk'
 make[660]: Entering directory `/c/projects/PostGIS/trunk'
 make[661]: Entering directory `/c/projects/PostGIS/trunk'
 And it keeps on incrementing and then it finally dies with
 make[138]: *** [clean] Interrupt
 make[137]: *** [clean] Interrupt
 make[136]: *** [clean] Interrupt
 make[135]: *** [clean] Interrupt
 make[134]: *** [clean] Interrupt
 I'll try to blow out my trunk and see if that fixes things.  Am I the only
 one having this problem?  Seems to have started as soon as you deleted the
 GNUMakefile and replaced with .in at #6404
Ticket URL: <http://trac.osgeo.org/postgis/ticket/713>
