[postgis-devel] Death to Pointless Operators
Paragon Corporation lr at pcorp.us
Tue Dec 21 10:59:53 PST 2010
Yes.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, December 21, 2010 1:35 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Death to Pointless Operators
These are n-dimensional indexes now.
left/right/above/below/overleft/overright are defined on the first two axes,
they make sense (to the extent that the make sense at all) in a 2d context.
Should I just implement them in 2d and ignore the higher dimensions?
P.
On Tue, Dec 21, 2010 at 2:32 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> I vote that we Destroy, Destroy, Destroy, leaving behind only
>> &&  bbox overlaps
>> @  bbox within
>> ~  bbox contains
>> ~=  bbox same
>> P.
> -1. I definitely have a use case for geometry_left/below/right/above
> which is you can use a binary search to quickly find the real extent
> of a stupidly large dataset using only the index.
> Secondly, the operators are synchronised with the PostgreSQL R-Tree
> operators and so we could potentially prevent users from moving their
> application from native PostgreSQL over to PostGIS.
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
