[postgis-devel] Death to Pointless Operators
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue Dec 21 11:28:01 PST 2010
Paul Ramsey wrote:
> These are n-dimensional indexes now.
> left/right/above/below/overleft/overright are defined on the first two
> axes, they make sense (to the extent that the make sense at all) in a
> 2d context. Should I just implement them in 2d and ignore the higher
> dimensions?
> P.
IMO this is the wrong approach. The correct way to do this would be to
implement a new GiST opclass for the higher dimensions which is likely
based upon the contrib/cube operators and operator class. Then users
specify at build time what dimensionality they want in the index and we
can match an existing operator class API/behaviour for migration purposes.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
