[postgis-devel] Gserialized Enabled vs Disabled
Paragon Corporation lr at pcorp.us
Thu Dec 30 22:06:36 PST 2010
I'm seeing a bunch of differences when doing a regress compare between these
two
Mostly with the way they handle empty geometries and the newer types like
TIN.
It's almost as if the serialized is not doing any short-circuiting and the
non-serialized is.
For example:
1)  SELECT ST_Disjoint(ST_GeomFromEWKT('SRID=4326;POINT(-11.1111111 40)'),
ST_GeomFromEWKT('SRID=4326;TRIANGLE((-71.0821 42.3036,-71.0821
42.3936,-71.0901 42.3036,-71.0821 42.3036))'))
In the regular case - non-gserialized:
This returns: t
In the gserialized -- this returns
Unknown geometry type: 14 - Triangle
So it's like the non-gserialized is smart enough to realize that if the
bounding box does not intersect there is no need to jump into geos or do
anything further analysis - it knows they are disjoint.
I'm seeing a lot of these silly failures.  Which are perhaps by design.
Thanks,
Regina
