[postgis-devel] Calling Index Genii
Paul Ramsey pramsey at opengeo.org
Thu Dec 30 22:15:36 PST 2010
Actually, testing again on the laptop (apples to apples) the speed
different with 2D data is down to 3ms-on-new vs 1ms-on-old. When
pulling a much larger result set (2000 records) the speed difference
is 10ms-on-new vs 6ms-on-old. So it's closer, but still not
equivalent.
P.
On Thu, Dec 30, 2010 at 4:07 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Well, it was a great theory, but my test did not bear it out. Even
> with 2D inputs the new index is still taking about 5x longer to return
> a small result set as the old one. :(
> P
> On Thu, Dec 30, 2010 at 3:32 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> You edit the postgis/gserialized.h file and define or undef GSERIALIZED_ON
>> BTW, I have a theory now which I just need to test... the data are 3D!
>> And in fact the new GiST index will build an index WITH DIMENSIONALITY
>> DETERMINED BY THE DATA. Not by the opclass. So the tree built with the
>> new index is going to be more expensive to search in 2D than an actual
>> 2D tree would have been. I just need to change my input data to 2D and
>> see if the performances fall into line to confirm my guess.
>> P.
>> On Thu, Dec 30, 2010 at 12:50 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>On my lap top the loading and index building take about the same
>>>>amount of time, but the query runs in about 1ms for the old index and
>>>>about 5ms for the new one. My assumption (thus unconfirmed) is that
>>>>the problem is not in the consistent checks (doing things like
>>>>reducing the size of the slice detoasted to the minimum necessary for
>>>>2d queries only improved the times by about 10%) but rather in the
>>>>tree itself: that the new index is just building a crappier tree, so
>>>>the query has to traverse more of it to get the same answer.
>>> There even an increase of memory resource needed ?
>>> To test this version there is a new key setting to apply in the .configure,
>>> or need to change manually the definitions ?
>>> Andrea Peri
>>> qwerty àèìòù
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
