[postgis-devel] Calling Index Genii
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Dec 31 04:11:16 PST 2010
On 31/12/10 06:15, Paul Ramsey wrote:
> Actually, testing again on the laptop (apples to apples) the speed
> different with 2D data is down to 3ms-on-new vs 1ms-on-old. When
> pulling a much larger result set (2000 records) the speed difference
> is 10ms-on-new vs 6ms-on-old. So it's closer, but still not
> equivalent.
> P.
Sounds like it's time to build a profileable version of the library. Can
you build with CFLAGS="-O0 -pg" and then use your favourite profiling
tool (gprof/Shark) to see the differences in where the time is being spent?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
