[postgis-devel] [PostGIS] #747: ST_OrderingEquals of GEOMETRYCOLLECTION EMPTY
PostGIS trac at osgeo.org
Fri Dec 31 11:23:50 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 But to add very disturbingly.
 For the gserialized while the ST_GeomFromText is false,
 The answer to this:
 SELECT ST_OrderingEquals(foo1.the_geom, foo1.the_geom) As result
         FROM (
                  (SELECT ST_GeomFromEWKT('SRID=4326;GEOMETRYCOLLECTION
 EMPTY') As the_geom )
                 ) As foo1 ;
 Is True.  It's as if the GeomFromEWKT and FromText are creating two
 different things indistiguishable from each other in text but binary
 different.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/747#comment:1>
