[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Dec 31 14:07:25 PST 2010
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 try-ing to load a shapefile on postgis 2.0.0 trunk using shp2pgsql.exe I
 notice that it produce a wrong sql file if the destination table has a
 schema.
 Infact if I call using:
 shp2pgsql.exe" -s 3003 -d -g geom -D -i -I -W "UTF-8" comuni.shp
 public.comuni > comuni.sql
 asking to put the data in a table of a public schema I see the sql file a
 wrong schema name having a dot not necessary:
 'public.'
 I add a portion of the sql generate to see the wrong schema name used.
 This error is available even in the debian compiled from source.
 SET CLIENT_ENCODING TO UTF8;
 SET STANDARD_CONFORMING_STRINGS TO ON;
 SELECT DropGeometryColumn('public.','comuni','geom');
 DROP TABLE "public."."comuni";
 BEGIN;
 CREATE TABLE "public."."comuni" (gid serial PRIMARY KEY,
 "area" float8,
 "perimeter" float8,
 "am_com_" float8,
 "am_com_id" float8,
 "codcom" varchar(6),
 "nome" varchar(100),
 "codprov" varchar(3));
 SELECT
 AddGeometryColumn('public.','comuni','geom','3003','MULTIPOLYGON',2);
 COPY "public."."comuni"
 ("area","perimeter","am_com_","am_com_id","codcom","nome","codprov",geom)
 FROM stdin;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748>
