[postgis-devel] [PostGIS] #318: 900913->4326 Transform
trac at osgeo.org
Sat Jan 9 06:24:10 PST 2010
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.4.1
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by arthurnederlof):
Replying to [comment:9 mcayland]:
> Hi Arthur,
> If you look at the thread above, the issue is that so far only Paul can
reproduce the error. You can help us by giving as much information about
your system, OS, PostgreSQL version, GEOS version and PROJ version as
possible, as well as complete test case.
> HTH,
> Mark.
Mark,
No problem, the probem is very consistent.
below the enviromnet, testoutput and a small demoprogram.
The used testcoordinates are from Cologne, germany, but all tested
coordinates in Europe give the same problem.
If you need more, please ask.
Arthur
system: GNU bash, version 3.2.48(1)-release (x86_64-pc-linux-gnu)
postgresql:"PostgreSQL 8.3.9 on x86_64-pc-linux-gnu, compiled by GCC
gcc-4.3.real (Ubuntu 4.3.3-5ubuntu4) 4.3.3"
postgis:"POSTGIS="1.4.1" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec
2007" USE_STATS"
Output testprogram:
15:18:13,445 INFO test::15 - start testrun
15:18:13,449 DEBUG DbfMaintenance::483 - Access to postGreSql on
jdbc:postgresql://10.13.54.8:5432/osm, user= arthur
15:18:13,581 DEBUG test::54 - postgreql version = PostgreSQL 8.3.9 on
x86_64-pc-linux-gnu, compiled by GCC gcc-4.3.real (Ubuntu 4.3.3-5ubuntu4)
4.3.3
15:18:13,582 DEBUG test::55 - postgis version = POSTGIS="1.4.1"
GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS
15:18:13,582 DEBUG test::60 - sql:select osm_id, name from
planet_osm_polygon where
(ST_Contains(way,ST_Transform(ST_SetSRID(ST_MakePoint(6.95,50.9333333),4326),900913)))
limit 1
15:18:13,591 DEBUG test::63 - name = Köln, Stadt
15:18:13,592 DEBUG test::68 - sql:select osm_id, name, ST_AsGeoJSON(
ST_TransForm(ST_setSRID(St_Box2D(way)::box2d,900913),4326),6 ) as box from
limit 1
15:18:13,620 DEBUG test::75 - problem with sql : ERROR: transform:
couldn't project point (753919 6.59133e+06 0): failed to load NAD27-83
correction file (-38)
Hint: PostGIS was unable to transform the point because either no grid
shift files were found, or the point does not lie within the range for
which the grid shift is defined. Refer to the ST_Transform() section of
the PostGIS manual for details on how to configure PostGIS to alter this
behaviour.
15:18:13,620 DEBUG DbfMaintenance::507 - disconnected to database.
15:18:13,621 INFO test::17 - Run postgistest OK
The testrountine itself:
public static String demontratePostgisProblem(double lat, double
lon){
Connection conn=DbfMaintenance.getPgDbConn();
String sql="";
try {
Statement stmt= conn.createStatement();
stmt = conn.createStatement();
ResultSet rset;
rset = stmt.executeQuery ("select version() as
postresqlversion, postgis_full_version() as postgisversion");
while (rset.next()) {
logger.debug("postgreql version =
"+rset.getString("postresqlversion"));
logger.debug("postgis version =
"+rset.getString("postgisversion"));
// this does work
sql = "select osm_id, name from planet_osm_polygon"+
" where
(ST_Contains(way,ST_Transform(ST_SetSRID(ST_MakePoint("+lon+","+lat+"),4326),900913)))
limit 1";
logger.debug("sql:"+sql);
rset = stmt.executeQuery (sql);
logger.debug("name = "+rset.getString("name"));
//this one gives the error for 4326, 4267 works ok
sql = "select osm_id, name, ST_AsGeoJSON(
" where
limit 1";
logger.debug("box = "+rset.getString("box"));
} catch (SQLException e) {
logger.debug("problem with sql :
"+e.getMessage());
DbfMaintenance.closeDbConn(conn);
return"OK";
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:10>
