[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
PostGIS trac at osgeo.org
Wed Jan 20 17:13:24 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 fixed after Mark's last change.  The make check is a separate issue so
 will open another ticket for that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:35>
