[postgis-devel] [PostGIS] #384: documentation and clearifying of ~= change
trac at osgeo.org
Wed Jan 20 23:50:47 PST 2010
Reporter: nicklas | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.1
Component: postgis | Version:
Resolution: | Keywords:
Comment (by nicklas):
I will try to come up with some rough doc before final release of 1.5.0
[[BR]]
Now the doc gives wrong information, and I guess some poor information is
better than wrong information. [[BR]]
The problem I think is that ~= was that much faster solution than
ST_OrderingEquals in 1.4 and below. Because of that it might be quite
commonly used.
And the difference between bounding box comparation and geometry_same will
not show in majority of situations but might be a very important
difference in others.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/384#comment:4>
