[postgis-devel] [PostGIS] #384: documentation and clearifying of ~= change
PostGIS trac at osgeo.org
Thu Jan 21 04:27:21 PST 2010
  Reporter:  nicklas  |       Owner:  nicklas
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Changes (by robe):
  * owner:  robe => nicklas
  * milestone:  PostGIS 1.5.1 => PostGIS 1.5.0
Comment:
 Nicklas,
 I'll take that as a volunteer from you it shove it over to you.  Hmm this
 is beginning to feel like musical chairs.
 Probably worthwhile noting that since the operator can't be dropped, if
 you soft upgraded from PostGIS 1.3  and never did a hard upgrade ~= still
 behaves like an exact geometry operator and if you soft-upgraded.  If your
 first version of PostGIS was 1.4.0 then it behaves like a bbox operator,
 but if you soft-upgraded from 1.4.1 (that being your first version or did
 a hard upgrade, then it behaves like a geometry equality operator).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/384#comment:5>
