[postgis-devel] [PostGIS] #544: alias construct fails in SELECT
PostGIS trac at osgeo.org
Thu Jun 17 04:58:15 PDT 2010
  Reporter:  darkblueb  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 1.5.2
 Component:  postgis    |     Version:  1.5.X
Resolution:  invalid    |    Keywords:
Changes (by mcayland):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 This suggests to me that "area" is already defined somewhere else in theq
 query - perhaps it is already a column within your constrained_sum2 or
 ct_sac_0 tables?
 I know that per the SQL spec, you are not allowed to reference an existing
 column alias within a select, e.g.
 SELECT st_area(col) AS foo, foo / 10 AS bar
 is illegal. You need to repeat it again, e.g.
 SELECT st_area(col) AS foo, st_area(col) / 10 AS bar
 HTH,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/544#comment:1>
