[postgis-devel] ST_GeometrySplit
strk strk at keybit.net
Thu Mar 11 07:03:42 PST 2010
On Wed, Mar 10, 2010 at 11:49:18AM -0800, Chris Hodgson wrote:
> It would be nice if the results were separated into "left" and "right".
> So you might return a geometrycollection which always contains 2
> components, the first one always being the left side and the second
> being the right. The geometries in the collection would have the
> appropriate type, perhaps minimized to the "lowest" applicable type
> (line vs. multiline or poly vs. multipoly).
2 components only seems to be the most wanted, so I'd go for it.
COLLECTION vs. ARRAY vs. SET I'm still thinking about.
Surely if order is important a simple GEOMETRY SET wouldn't be
appropriate as SETs are unordered by definition.
> Right-side vs left side can be ambiguous too... an example is a circle
> or spiral that is split by a line on only one side. Perhaps a 3rd
> component to the resulting collection?
For a LINESTRING only the segment being split (or the two segments
being split on their conjuncting nodes) would be taken in consideration.
Rather, in a multipoly or multiline we'll  have to put the not-being-cut
parts either in one or the other component. Could be we always take
the first component as being the "left over" and the second component
as being the "cut-away" part and hard-code the fact that you always
"cut-away" the part on the right.
Example 1:
 |  |    +---+  THIS IS THE "left over"
    |  |        THIS IS THE "cut-away"
Example 2:
    v
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
