[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
PostGIS trac at osgeo.org
Tue May 4 13:54:31 PDT 2010
  Reporter:  loldrup   |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  backend terminated exception
Comment (by robe):
 There have been a couple of leak fixes in GEOS since 3.2.0 was released.
 Before you send a dump, can you try the GEOS 3.2.2 libraries.
 They are packaged in with the PostGIS 1.5.2SVN experimental builds.  You
 just need to copy the geos* from the bin folder of that to your PostgreSQL
 bin folder.  Backup your geos* .dlls first before overwriting.
 http://www.postgis.org/download/windows/experimental.php
 Then to verify just do a
 SELECT postgis_full_version();
 and it should register the new GEOS.
 If you still have problems with the new GEOS then a dump would be helpful
 to troubleshoot.
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:2>
