[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
PostGIS trac at osgeo.org
Fri May 7 10:41:54 PDT 2010
  Reporter:  loldrup   |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  backend terminated exception
Comment (by pramsey):
 Probably you can make it fail faster by lowering shared_buffers then,
 right?
 Yes, it might be a leak.
 I mean, building PostGIS against, and running it inside a PostgreSQL that
 has been build with --enable-cassert.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:14>
