[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
trac at osgeo.org
Sat May 8 02:19:03 PDT 2010
Reporter: loldrup | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone:
Component: postgis | Version: 1.4.X
Resolution: | Keywords: backend terminated exception
Comment (by loldrup):
The "64MB shared_buffes setting" test died at 07:00:53 local time(GMT+2),
and the last I saw of the backend's was at 00:45:00 where memory usage was
148MB pr. backend after 902.000 JMeter samples.
Changed to 16MB shared_buffes setting, and the exact same test stops after
only 500 samples.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:18>
