[postgis-devel] mingw autotools
Paul Ramsey pramsey at opengeo.org
Tue May 11 19:13:18 PDT 2010
It got more confusing, unfortunately. I had an older VM configured
exactly to the old wiki page and the autotools there spit out a usable
configure. So the problem (maybe?) is with moving up to the latest
minor version of MingGW? So I don't know what the answer is except
that building with MinGW is impossibly confusing. If VCC can offer a
saner build situation it might be worth the time spent to just suck it
up and go to a pure VCC build. Proj and GEOS already build in VCC as
does pgsql so it's just postgis to do...
P.
On Tue, May 11, 2010 at 6:24 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> Which version of GEOS are you configuring?
> Like I mentioned I haven't had problems with GEOS <= 3.2.2 , but the 3.3.0
> just can't build under mingw.  Which I suspect you are running into the same
> issues?
> I think it builds fine under my VS /VS Express environments last I checked.
> Which  of course vastly limits my ability to test anything in the PostGIS
> 2.0 trunk (aside from I have issues - can't build even against old GEOS the
> trunk under mingw)
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Tuesday, May 11, 2010 7:40 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] mingw autotools
> Winguys and wingals,
> Trying to follow the generic build instructions on the Wiki, I've found that
> I simply cannot use the mingw/msys autotools to generate a GEOS configure
> file. If I generate one on OSX and copy it over I can build GEOS, but the
> mingw tools create a configure which then fails to detect int64 (and god
> knows what else) which leads to various failures.
> I can hack around this limitation as I always have, but I'm wondering if
> there's some unwritten magic you've got going on. I used the instructions,
> but I got no love.
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
