[postgis-devel] searching for geometry type in wrong schema
Nicklas Avén nicklas.aven at jordogskog.no
Wed May 12 15:59:56 PDT 2010
Hallo
I have bumped into something very strange I think.
I am trying to get postgisonline.org work smoothly with multiple versions of postgis.
The solution I am now trying I guess is somewhere in the outer parts of what is recommended but I have found that the easiest administration of the datasets to use in postgisonline is if everything is in the same database.
Because of that I have installed postgis 1.5.1 in public schema as usual and Postgis trunk in a schema called trunk. Then I have different users with different search_path and decide what version to use by changing connection parameters.
This worked just great until a removed public schema from the search_path for the trunk version. Then some functions stopped working with the error, for instance:
function ST_Srid(public.geometry) does not exist
What is strange is that ST_Area works fine and ST_Distance and ST_Length, but not ST_Dump
The question I don't understand right now is what decides where to get the type. From what I understand ST_Srid reads the type from the public schema and complains that the ST_Srid function in the trunk schema doesn't like the public.geometry type. I also guess that ST_Area does what is expected and uses the geometry type specified in the trunk schema and the ST_Area function get satisfied since it expects ST_Area(trunk.geometry)
My first thought is that there is some hard coded path to public schema in some functions. But I really don't know because in my local install, not postgisonline, I get different result. First all seemed to work and now nothing seems to work.
This is of course a very small issue and there is workarounds, but if this is a bug it might give other unexpected behaviours I guess.
If you want to see the phenomena on postgisonline you can get the trunk search_path by using this address:
http://www.postgisonline.org/map.php?version=trunk
then you can try against a table called roads. All queries producing a geometry column called the_geom will give an error because there is an srid check which causes the error above.
but try
Select ST_Length(the_geom) from roads;
or
Select ST_Area(the_geom) from property;
and it should work. But :
Select ST_Srid(the_geom) from roads;
 will give error
Any ideas?
Is it a PostgreSQL bug or a PostGIS bug or am I the bug myself?
Thanks
Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100513/77fe1715/attachment.html>
