[postgis-devel] [PostGIS] #471: Documentation errors against docbook 4.3 dtd
PostGIS trac at osgeo.org
Wed Oct 13 14:58:57 PDT 2010
  Reporter:  colivier  |       Owner:  colivier
      Type:  defect    |      Status:  reopened
  Priority:  medium    |   Milestone:  PostGIS 2.0.0
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  doc docbook dtd
Changes (by colivier):
  * status:  closed => reopened
  * version:  1.5.X => trunk
  * resolution:  fixed =>
  * milestone:  PostGIS 1.5.2 => PostGIS 2.0.0
Comment:
 installation.xml:11: element note: validity error : Element note content
 does not follow the DTD, expecting (title? , (calloutlist | glosslist |
 itemizedlist | orderedlist | segmentedlist | simplelist | variablelist |
 literallayout | programlisting | programlistingco | screen | screenco |
 screenshot | synopsis | cmdsynopsis | funcsynopsis | classsynopsis |
 fieldsynopsis | constructorsynopsis | destructorsynopsis | methodsynopsis
 | formalpara | para | simpara | address | blockquote | graphic | graphicco
 | mediaobject | mediaobjectco | informalequation | informalexample |
 informalfigure | informaltable | equation | example | figure | table |
 procedure | sidebar | anchor | bridgehead | remark | indexterm |
 beginpage)+), got (CDATA)
  support is currently optional, but in final release it will be
 required.</note>
 using_postgis_dataman.xml:143: element listitem: validity error : Element
 listitem content does not follow the DTD, expecting (calloutlist |
 glosslist | itemizedlist | orderedlist | segmentedlist | simplelist |
 variablelist | caution | important | note | tip | warning | literallayout
 | programlisting | programlistingco | screen | screenco | screenshot |
 synopsis | cmdsynopsis | funcsynopsis | classsynopsis | fieldsynopsis |
 constructorsynopsis | destructorsynopsis | methodsynopsis | formalpara |
 para | simpara | address | blockquote | graphic | graphicco | mediaobject
 | mediaobjectco | informalequation | informalexample | informalfigure |
 informaltable | equation | example | figure | table | msgset | procedure |
 sidebar | qandaset | task | anchor | bridgehead | remark | highlights |
 abstract | authorblurb | epigraph | indexterm | beginpage)+, got (CDATA
 para )
                 </listitem>
 using_postgis_dataman.xml:147: element listitem: validity error : Element
 para )
                 </listitem>
 using_postgis_dataman.xml:152: element listitem: validity error : Element
 para )
                 </listitem>
 reference_accessor.xml:783: element listitem: validity error : Element
 abstract | authorblurb | epigraph | indexterm | beginpage)+, got (CDATA)
                     <listitem>GEOMETRYCOLLECTION</listitem>
 reference_accessor.xml:784: element listitem: validity error : Element
 <listitem>MULTI{POINT,POLYGON,LINESTRING,CURVE,SURFACE}</listitem
 reference_accessor.xml:785: element listitem: validity error : Element
                     <listitem>COMPOUNDCURVE</listitem>
 reference_accessor.xml:793: element note: validity error : Element note
 content does not follow the DTD, expecting (title? , (calloutlist |
 variablelist | literallayout | programlisting | programlistingco | screen
 | screenco | screenshot | synopsis | cmdsynopsis | funcsynopsis |
 classsynopsis | fieldsynopsis | constructorsynopsis | destructorsynopsis |
 methodsynopsis | formalpara | para | simpara | address | blockquote |
 graphic | graphicco | mediaobject | mediaobjectco | informalequation |
 informalexample | informalfigure | informaltable | equation | example |
 figure | table | procedure | sidebar | anchor | bridgehead | remark |
 indexterm | beginpage)+), got (CDATA varname CDATA)
                 </note>
 reference_processing.xml:2253: element entry: validity error : Element
 informalfigure is not declared in entry list of possible children
                                         </entry>
 reference_processing.xml:2263: element entry: validity error : Element
                                         </entry>
 reference_processing.xml:2306: element entry: validity error : Element
                                         </entry>
 reference_processing.xml:2316: element entry: validity error : Element
                                         </entry>
 reference_raster.xml:374: element refentry: validity error : Syntax of
 value for attribute id of refentry is not valid
         <refentry id="RT_PostGIS_Raster_Lib_Build_Date()">
 reference_raster.xml:531: element ulink: validity error : No declaration
 for attribute href of element ulink
 rmat as commonly seen in a <ulink
 href="http://en.wikipedia.org/wiki/World_file"
 reference_raster.xml:531: element ulink: validity error : Element ulink
 does not carry attribute url
 en in a <ulink href="http://en.wikipedia.org/wiki/World_file">world
 file</ulink>
 reference_raster.xml:816: element note: validity error : Element note
 indexterm | beginpage)+), got (CDATA)
 n error will be raised if you give just the x column for a skewed
 raster.</note>
 reference_raster.xml:890: element note: validity error : Element note
                 An error will be raised if you give just the y row for a
 skewed raster.</note>
 reference_raster.xml:1385: element note: validity error : Element note
                                 </note>
 reference_raster.xml:2414: element note: validity error : Element note
                                         different from ST_ConvexHull which
 does not floor.</note>
 faq_raster.xml:229: element xref: validity error : Element xref was
 declared EMPTY this one has content
 r to the list of <xref linkend="RT_reference">documented raster
 functions</xref>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/471#comment:3>
