[postgis-devel] array construct in measures.c
Nicklas Avén nicklas.aven at jordogskog.no
Wed Sep 29 13:08:55 PDT 2010
Hallo
I saw that Paul has put a comment in measures.c that C90 doesn't support var-size array. I suspect that is what gave Sami problems when compiling PostGIS with Visual Studio as mentioned here: http://symbiatch.jutut.fi/article/2955
So, in attached patch, am I doing it the right way?
If so, should I backport to 1.5 too or only trunk?
/Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100929/b86c5cbc/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100929/b86c5cbc/attachment.obj>
