[postgis-devel] [PostGIS] #919: Documentation build errors again
PostGIS trac at osgeo.org
Wed Apr 20 20:22:26 PDT 2011
 Reporter:  robe           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  critical       |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 We seem to be having documentation build errors again and am stumped as to
 what could be wrong.  When it broke there was no change any of the places
 it was complaining about.  So I suspect its a recurrence of this #471.
 Wonder if we need to upgrade MathML to 3.0, but have no clue how all that
 works.  When I did make comments locally it would sometimes give arbitrary
 errors and sometimes complete fine so it doesn't seem to be a specific
 document error.
 Seems to be choking when building postgis_aggs_mm.xml file though when I
 did make comments it actually built the postgis_comments.sql and
 postgis_raster.sql and then choke on topology_comments.sql.  But then it
 worked fine the next time around.
 chmod +x postgis_restore.pl create_undef.pl postgis_proc_upgrade.pl
 profile_intersects.pl test_estimation.pl test_joinestimation.pl
 make[1]: Leaving directory `/var/home/buildbot/opt/hudson/jobs/PostGIS-
 trunk-build/workspace/build/utils'
 PostGIS was built successfully. Ready to install.
 + cd doc
 + mv postgis.xml postgis.xml.orig
 + sed -e 's:</title>:</title><subtitle><subscript>SVN Revision
 (<emphasis>7054</emphasis>)</subscript></subtitle>:' postgis.xml.orig
 + make -e chunked-html
 + tee -a doc-errors.log
 /usr/bin/xsltproc ./xsl/postgis_aggs_mm.xml.xsl postgis.xml >
 postgis_aggs_mm.xml
 http://www.oasis-open.org/docbook/xml/4.5/docbookx.dtd:171: parser error :
 EntityValue: '%' forbidden except for entities references
 EntityValue: " or ' expected
 xmlParseEntityDecl: entity list.class not terminated
 XML conditional section not closed
 unable to parse postgis.xml
 make: *** [postgis_aggs_mm.xml] Error 6
 + make comments
 /usr/bin/xsltproc ./xsl/postgis_comments.sql.xsl postgis.xml >
 /usr/bin/xsltproc ./xsl/raster_comments.sql.xsl postgis.xml >
 raster_comments.sql
 make: *** [raster_comments.sql] Error 6
 + make pdf
 and all I had changed when this started happening was this file
         /trunk/doc/xsl/postgis_gardentest.sql.xsl
 which doesn't even get called by the build.
 If anyone has insights into the problem, that would be much appreciated.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/919>
