[postgis-devel] [PostGIS] #920: CURVEPOLYGON problem when converting to/from text
PostGIS trac at osgeo.org
Thu Apr 21 18:26:21 PDT 2011
 Reporter:  debe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.3
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by robe):
 debe,
 I looked at this and I don't think it's a bug but just an unfortunate
 consequence of converting from geometry to text representation.  The first
 geometry in your compound curve is a linestring with only one point which
 is clearly invalid.  What I suspect happened is that the linestring in
 binary form had 2 points, but when converted to ST_AsText which only keeps
 15 decimal places or so, because the points were so close, it got reduced
 to 1 point and thus became invalid.
 To determine this, can you send us the binary or hex of the geometry
 e.g. do a SELECT geometry  (should output as hex)
 or a SELECT ST_AsBinary(geometry) ...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/920#comment:1>
