[postgis-devel] Planning of raster work to be integrated in PostGIS 2.0
Paul Ramsey
pramsey at opengeo.org
Fri Apr 29 15:19:51 PDT 2011
On Fri, Apr 29, 2011 at 2:05 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
> Hi all,
> 1) Should we make the effort (and take the risk) of integrating his work for PostGIS 2.0 or should we wait for PostGIS 2.1? Note that these functions are not documented yet.
If you think they're worth it.
> 2) When is the feature freeze planned? Is there going to be a branch done? How do you usually deal with future stuff to add during a release cycle?
I'm dealing with catching up on project work, which is too bad because
the main feature I have is still off to the side (new serialization
and typmod).
We haven't had to deal with this stuff during a release cycle, but my
preference would be to adopt the PgSQL standard and say "no new
feature commits during release, as it's distracting from where you
should be putting your effort (bugs and stability)".
> 3) When is the code freeze planned?
Summerish... ?
P
> Functions to integrate (each function have a certain number of variants):
> ST_Band(rast raster, bandnums int[]) #339
> ST_MinMax(rast raster, nband int, ignore_nodata boolean, OUT min float8, OUT max float8) #902
> ST_ApproxMinMax(rast raster, nband int, ignore_nodata boolean, sample float8, OUT min float8, OUT max float8) #902
> ST_Reclass(rast raster, nband int, reclassexpr text, pixeltype text, nodataval double precision) #903
> ST_AsGDALRaster(rast raster, format text, options text[], srs text) #901
> ST_AsTiff(rast raster, options text[], srs text) #341
> ST_AsPNG(rast raster, options text[], srs text) #342
> ST_AsJPEG(rast raster, options text[], srs text) #340
> Thanks,
> Pierre
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
