[postgis-devel] moving liblwgeom forward
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Aug 8 02:49:44 PDT 2011
On 05/08/11 19:20, Chris Hodgson wrote:
> Good to hear you've got some funding to do work on PostGIS!
+1. liblwgeom does need quite a bit of love at the moment.
> I'm a little bit worried about the effects of installing liblwgeom into
> the system lib dir on the ability to have multiple different versions of
> PostGIS installed simultaneously (for development, testing, migration,
> etc.). Tell me this won't be any different than it is now and I'll
> probably believe you.
> I can't imagine a situation where it makes sense for liblwgeom to have a
> different version than postgis. IIRC the only reason they are separated
> is to provide a C-based interface to test the liblwgeom functions
> without having to go through postgres.
Agreed :)
Let's version liblwgeom the same as PostGIS for the time being so we
start off with liblwgeom-2.0 and move the numbering to match the
corresponding PostGIS version.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
