[postgis-devel] Raster Regressing
dustymugs dustymugs at gmail.com
Wed Aug 10 16:51:14 PDT 2011
Paul,
Can you add a ticket for this?  I think you're the first mentioning that
there are problems with OSX.  I know we had issues with Windows and GDAL
but I think we've resolved those (Regina or Pierre may know more).
As I don't have access to an OSX machine, I hope you don't mind if I ask
you later for a valgrind output.
As for the offline raster tests, I think there is a ticket for
converting those tests to cunit but the work hasn't been done yet.
-bborie
On 08/10/2011 04:00 PM, Paul Ramsey wrote:
> Gdal 1.9-dev,
> OS/X 10.6.8
> On Wed, Aug 10, 2011 at 3:56 PM, dustymugs<dustymugs at gmail.com>  wrote:
>> On 08/10/2011 03:52 PM, Paul Ramsey wrote:
>>> I've got 6 failures in the raster online regressions (jeepers, is a
>>> backend crash), which I guess is what things were like before... and
>>> last time my response was just to stop testing raster for six months,
>>> which is probably not what you want people to do. Can we either get
>>> the tests to pass on all platforms or replace them with tests that do?
>>> Because faced with "should be right but are failing" tests, people
>>> just stop trusting the tests at all, or stop running them.
>>> I'm also quite non-fond of the offline raster tests, which are noisy
>>> and not at all clear on what's good and what's not. Is cunit not
>>> appropriate for them?
>>> P.
>>>   rt_asgdalraster. failed (diff expected obtained:
>>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_diff)
>>>   rt_astiff. failed (diff expected obtained:
>>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_11_diff)
>>>   rt_asjpeg. failed (diff expected obtained:
>>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_12_diff)
>>>   rt_aspng. failed (diff expected obtained:
>>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_13_diff)
>>>   rt_resample. failed (diff expected obtained:
>>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_41_diff)
>>>   rt_asraster. failed (diff expected obtained:
>>> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_42_diff)
>>> Tadpole:postgis-svn pramsey$ cat
>>> --- rt_asgdalraster_expected    2011-05-25 11:27:53.000000000 -0700
>>> +++ /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_out
>>>   2011-08-10
>>> 15:47:31.000000000 -0700
>>> @@ -5,11 +5,7 @@
>>>   1
>>>   1
>>>   1
>>> -1
>>> -1
>>> -1
>>> -1
>>> -1
>>> -1
>>> -1
>>> -1
>>> +server closed the connection unexpectedly
>>> +       This probably means the server terminated abnormally
>>> +       before or while processing the request.
>>> +connection to server was lost
>> Paul,
>> What version of GDAL are you running?  All the functions that are regressing
>> hook directly into the GDAL library.  Also, what OS are you running?
>> -bborie
