[postgis-devel] [PostGIS] #825: [raster] raster overview -- trying to insert into wrong table (if schema qualify), and not creating rast column
trac at osgeo.org
Tue Feb 15 20:34:22 PST 2011
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
On a related topic I think we are also agreed that we don't really need
the -V switch anymore. So the raster_overviews insert should not assume
the raster_overviews is in the same schema as the loading raster and also
for flexibility just not schema qualify the raster_overviews table
http://www.postgis.org/pipermail/postgis-devel/2011-February/011793.html
I have also confirmed that the raster2pgsql doesn't seem to do the
AddRasterColumn call for overviews or even create a raster column so
always requires manual edit or the file to work properly.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/825#comment:2>
