[postgis-devel] [PostGIS] #763: Topology_comments - createtopogeom(..) is missing
PostGIS trac at osgeo.org
Mon Jan 10 14:01:51 PST 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 I try the postgis200 (version 10JAN2010)on windows using postgres 9.0.2.
 seem to miss the createtopogeom() from topology_comments.
 I report the logs here.
 C:\Program Files (x86)\PostgreSQL\9.0>REM installs topology support
 C:\Program Files (x86)\PostgreSQL\9.0>"C:\Program Files
 (x86)\PostgreSQL\9.0\bin
 \\psql"  -d "template_postgis20" -f
 "share\contrib\postgis-2.0\topology\topology
 .sql"
 CREATE SCHEMA
 psql:share/contrib/postgis-2.0/topology/topology.sql:219: NOTICE:  CREATE
 TABLE
 will create implicit sequence "topology_id_seq" for serial column
 "topology.id"
 TABLE
 / PRIMARY KEY will create implicit index "topology_pkey" for table
 "topology"
 TABLE
 / UNIQUE will create implicit index "topology_name_key" for table
 "topology"
 CREATE TABLE
 CREATE FUNCTION
 psql:share/contrib/postgis-2.0/topology/topology.sql:321: NOTICE:  CREATE
 TABLE
 / PRIMARY KEY will create implicit index "layer_pkey" for table "layer"
 TABLE
 "layer_schema_name_table_name_feature_column
 _key" for table "layer"
 CREATE TABLE
 CREATE TRIGGER
 CREATE TYPE
 CREATE TYPE
 CREATE TYPE
 CREATE DOMAIN
 CREATE DOMAIN
 CREATE DOMAIN
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE CAST
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 psql:share/contrib/postgis-2.0/topology/topology.sql:2799: NOTICE:
 aggregate to
 pology.topoelementarray_agg(topology.topoelement) does not exist, skipping
 DROP AGGREGATE
 CREATE AGGREGATE
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 _comments.sql"
 SET
 COMMENT
 COMMENT
 COMMENT
 COMMENT
 COMMENT
 COMMENT
 COMMENT
 psql:share/contrib/postgis-2.0/topology/topology_comments.sql:18: ERROR:
 functi
 on createtopogeom(character varying, character varying, integer,
 topoelementarra
 y) does not exist
Ticket URL: <http://trac.osgeo.org/postgis/ticket/763>
