[postgis-devel] [PostGIS] #1102: Memory leaks in liblwgeom ?
PostGIS trac at osgeo.org
Mon Jul 4 05:31:39 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 With r7578 I've fixed a few leaks which were in the unit tests themselves,
 but next big leak really comes from library, and is related to WKT errors
 during parsing. It is triggered by passing 'TIN(((0 1 2,3 4 5,6 7 8,9 10
 11,0 1 2)))' to lwgeom_from_ewkt. The code will allocate a POINTARRAY and
 then bail out calling lwerror, failing to release the allocated POINARRAY.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1102#comment:1>
