[postgis-devel] [PostGIS] #1023: topology regress failures related to GSERIALIZED: copytopology and
PostGIS trac at osgeo.org
Mon Jul 4 06:05:14 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 The idea of the test is to make sure that all we had in one table is also
 present in the other table. I've to say that a bounding-box only btree
 check there isn't that strong so could change the test to use hexwkb
 output for geometries instead.
 But then I wonder if btree should really be bounding-box based only...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1023#comment:2>
