[postgis-devel] [PostGIS] #1030: [raster] ST_SummaryStats on coverage crashes with the sample_percent parameter
PostGIS trac at osgeo.org
Fri Jun 17 07:46:16 PDT 2011
parameter
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Now this gets very strange.  It appears that PostgreSQL is passing your
 second example
 SELECT *
 FROM st_summarystats('srtm_22_03_tiled_100x100', 'rast', FALSE, 1.0);
 to the function
 ST_SummaryStats(rast raster, nband int DEFAULT 1, exclude_nodata_value
 boolean DEFAULT TRUE, sample_percent double precision DEFAULT 1)
 I tested this by deleting all ST_SummaryStats functions and adding them
 back one at a time.  If you explicitly cast the first parameter of your
 example, you get the appropriate message "No function matches the given
 name and argument types. You might need to add explicit type casts.".
 SELECT *
 FROM st_summarystats('srtm_22_03_tiled_100x100'::text, 'rast', FALSE,
 1.0);
 It appears that PostgreSQL is interpreting 'srtm_22_03_tiled_100x100' as a
 raster type and 'rast' as an integer.  I don't know what I can do about
 the function parameter type conversion.
 http://www.postgresql.org/docs/8.4/static/typeconv-func.html
 Besides, no function exists for your second example.  Granted, we could
 modify one function declaration to add a parameter for the sample_percent.
 If we don't modify that one declaration though, it would be best to
 consider this ticket as a "won't fix".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1030#comment:2>
