[postgis-devel] [PostGIS] #1000: box3d_extent output is 2d, casted to box3d makes up random numbers
PostGIS trac at osgeo.org
Sun Jun 19 07:59:36 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  boxes    |
Changes (by simoc):
 * cc: simoc (added)
Comment:
 Problem is that struct returned to SQL from C function
 BOX3D_extent_to_BOX3D() is not fully initialised.
 Solution is to add two lines to this C function.  A diff of the required
 changes is:
 $ diff /tmp/postgis-2.0.0SVN/postgis/lwgeom_box3d.c
 ./postgis/lwgeom_box3d.c
 186a187,188
 >       out->zmin = 0;
 >       out->zmax = 0;
 I am working with the current SVN revision 7429 postgis-2.0.0SVN.tar.gz
 source.
 Can someone with commit access please commit this change.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1000#comment:1>
