[postgis-devel] [PostGIS] #110: shp2pgsql new option to not batch commit
PostGIS trac at osgeo.org
Wed Mar 16 10:20:58 PDT 2011
  Reporter:  robe         |       Owner:  mcayland
      Type:  enhancement  |      Status:  closed
  Priority:  low          |   Milestone:  PostGIS Future
 Component:  postgis      |     Version:  trunk
Resolution:  fixed        |    Keywords:
Changes (by jadams):
  * status:  new => closed
  * resolution:  new => fixed
Old description:
> '''What steps will reproduce the problem?'''
> 1. If you have some geometries that fail insert such as polygons without
> closed rings, it kills the current batch and gives a more or less
> meaningless message
> 2. This has happened to me a lot and a lot of users we train.  A lot of
> the
> time the data should just rightfully not be added.
> 3. Write now to overcome this I generate a .sql file and use sed to
> remove
> the begin commits which means I can't use the normal | to directly load
> I think the simplest option is to allow users with a flag to have the
> option to not have begin commits so that everything is in its own
> transaction.  That way at least a whole batch of good records aren't lost
> because of one bad apple.
> I know we have talked about other options such as allowing these beasts
> into the database or nulling the geometry if invalid etc -- though those
> options are trickier to implement and may not handle all cases.
New description:
 meaningless message
 the
 3. Write now to overcome this I generate a .sql file and use sed to remove
Comment:
 At some point (probably the refactoring into -core that happened for 1.5)
 this behavior was changed to always use a single transaction, rather than
 one per 250 records.
 I've added a "-e" command line flag that prevents using a transaction.
 Revision 6909 in trunk.
 The discussion of what to do with invalid geometries has been moved into
 its own ticket:
 http://trac.osgeo.org/postgis/ticket/859
Ticket URL: <http://trac.osgeo.org/postgis/ticket/110#comment:16>
