[postgis-devel] [PostGIS] #868: Error in check of circularstring
PostGIS trac at osgeo.org
Fri Mar 18 09:50:14 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 try-ing to compile the version r6925 I see this error.
 sql-mm-circularstring. failed (diff expected obtained:
 /tmp/pgis_reg_27315/test_35_diff)
 I attach the logs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/868>
