[postgis-devel] [PostGIS] #894: _ST_Expand for geography is broken
PostGIS trac at osgeo.org
Thu Mar 31 10:04:20 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 I think this may be related to #869.
 In trying to trace the cause of failure of ST_DWithin in 869, I discovered
 that
 _ST_Expand for any geography type for any distance always returns the same
 geography.  What was especially puzzling is that it is also broken in
 PostGIS 1.5.2 and yet the ST_DWithin in that works.
 _ST_DWithin by itself works fine and produces the correct answers in that
 regress for both 2.0 and 1.5.2 -- so the failing part is the _ST_Expand.
 My conclusion is that while PostGIS 1.5.2 is also broken, the cached box
 it produces must be right, but that when Paul enable the gserialized, it
 somehow probably made the cached box agree with the output geometry thus
 making the _ST_Expand ineffective in 2.0.
 I'm not sure how to see the cached box of a geography though?  Do we have
 a function for that?
 So here is the case:
 On PostGIS 1.5.2 and PostGIS 2.0
 SELECT ST_AsText(_ST_EXPAND(ST_GeogFromText('LINESTRING(1 2, 3 4)'), 1000
 -- result--
 LINESTRING(1 2,3 4)
 However watch this:
 SELECT _ST_EXPAND(ST_GeogFromText('LINESTRING(1 2, 3 4)'), 1000) &&
 ST_GeogFromText('POINT(3 3)');
 On 1.5 the above returns true, but on our new 2.0 after Paul's changing
 the switch to make gserialized live, it now returns false.
 So PostGIS 2.0 is more or less more or less broken than 1.5. It's just
 that 1.5 is covering its tracks in ways we usually check.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/894>
