[postgis-devel] [PostGIS] #969: [raster] duplicate functions with different named args
PostGIS trac at osgeo.org
Sat May 21 09:39:12 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 You would only see this error in PostgreSQL 9.0.  In PostgreSQL 8.4, it
 would just install the last one I think.
 So the error I get is:
 psql:share/contrib/postgis-2.0/rtpostgis.sql:1471: ERROR:  cannot change
 name of input parameter "pixeltype"
 HINT:  Use DROP FUNCTION first.
 The issue is your ST_MapAlgebra have arguments lists that are not in same
 order but have the same type.  This is illegal in PostgreSQL 9.0+ because
 PostgreSQL 9.0+ supports named arguments
 which means I can do ST_MapAlgebra(pixeltype:='8BUI',...) completely out
 of order.  But since the way your functions are written could result in an
 ambiguous function path, your orders need to be the same.  Sorry if I'm
 not making sense.
 --Any rate your issue is here.  This is illegal in PostgreSQL 9.0+.
 I think you just need to swap the order of pixeltype and nodataexpress
 -- This function can not be STRICT, because nodatavalueexpr can be NULL
 (could be just '' though)
 -- or pixeltype can not be determined (could be st_bandpixeltype(raster,
 band) though)
 CREATE OR REPLACE FUNCTION st_mapalgebra(rast raster, expression text,
         nodatavalueexpr text, pixeltype text)
     RETURNS raster
     AS $$ SELECT st_mapalgebra($1, 1, $2, $3, $4) $$
     LANGUAGE SQL;
         nodatavalueexpr text)
     RETURNS raster
     AS $$ SELECT st_mapalgebra($1, 1, $2, $3, NULL) $$
     LANGUAGE SQL;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/969>
