[postgis-devel] [PostGIS] #968: ST_ChangeEdgeGeom - missing document
trac at osgeo.org
Mon May 23 20:07:04 PDT 2011
Reporter: aperi2007 | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: documentation | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
documented at r7216, also made some customizations to the function to get
rid of redundant && and change to pass by name instead of just variable
type.
strk,
Can you check this function. for the intersects check, isn't it okay for
the end nodes to intersect and existing edge? Also don't see a check to
confirm that an edge actually exists. I'll put that in as a bug in a
separate ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/968#comment:1>
