[postgis-devel] [PostGIS] #992: [raster] PostGIS raster && operator not installed when GSERIALIZED_ON
PostGIS trac at osgeo.org
Thu May 26 18:54:08 PDT 2011
 Reporter:  robe            |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by robe):
  * owner:  pracine => pramsey
Comment:
 Paul,
 Maybe you should tackle this one or tell us what needs to be done here.
 The issue is raster operator is defined like this:
 CREATE OPERATOR && (
     LEFTARG = raster, RIGHTARG = raster, PROCEDURE = st_overlap,
     COMMUTATOR = '&&',
     RESTRICT = geometry_gist_sel, JOIN = geometry_gist_joinsel
 My first thought was to include the gserialized header in there and then
 change to this to match the way you have geometry:
 #ifdef GSERIALIZED_ON
     COMMUTATOR = '&&',
     RESTRICT = contsel, JOIN = contjoinsel
 #else
     COMMUTATOR = '&&',
 #endif
 But I've never understood the difference between contsel and
 geometry_gist_sel and why I wouldn't just go with contsel, contjoinsel in
 both the GSERIALIZED ON/OF cases and then not have to include the header
 file.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/992#comment:3>
