[postgis-devel] [PostGIS] #993: Crash when try to cast to a box2d with GSERIALIZED ON
PostGIS trac at osgeo.org
Thu May 26 19:23:37 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 SELECT 'BOX(7.5 2.5,12.5 7.5)'::box2d
 Crash.  This I discovered when testing raster create_rt_box2d_test.sql
 but isolated down to the act of just casting to a box2d.  Probably causing
 a lot of the failures in topology too I suspect.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/993>
