[postgis-devel] [PostGIS] #1227: server crash on invalid gml in st_geomfromgml
PostGIS trac at osgeo.org
Wed Oct 5 01:30:50 PDT 2011
 Reporter:  wbloos               |       Owner:  pramsey
     Type:  defect               |      Status:  new
 Priority:  medium               |   Milestone:  PostGIS 1.5.4
Component:  postgis              |     Version:  1.5.X
 Keywords:  gml, invalid, crash  |
 PostgreSQL crashes when i send it an 'invalid' gml in st_geomfromgml(().
 In fact the gml is not invalid AFAIK, but it might be considered a
 GML-document instead of a GML-fragment.
 The server is supposed to throw an error when that happens, but it
 crashes.
 query:
 select st_geomfromgml('<OriginalGeometry gml:id="1" srsDimension="2"
 srsName="EPSG:28992" xsi:type="gml:PointType"
 xmlns:ns="http://willy-bas.nl/yes/"
 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:gml="http://www.opengis.net/gml/3.2">
  <gml:Point>
    <gml:posList>600000 300000</gml:posList>
  </gml:Point>
 </OriginalGeometry>')
 Response:
 server closed the connection unexpectedly
        This probably means the server terminated abnormally
        before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 2011-10-04 09:48:37 CEST pid=995 LOG:  server process (PID 5181) was
 terminated by signal 11: Segmentation fault
 2011-10-04 09:48:37 CEST pid=995 LOG:  terminating any other active
 server processes
 2011-10-04 09:48:37 CEST pid=5180 WARNING:  terminating connection
 because of crash of another server process
 2011-10-04 09:48:37 CEST pid=5180 DETAIL:  The postmaster has
 commanded this server process to roll back the current transaction and
 exit, because another server process exited abnormally and possibly
 corrupted shared memory.
 2011-10-04 09:48:37 CEST pid=5180 HINT:  In a moment you should be
 able to reconnect to the database and repeat your command.
 2011-10-04 09:48:37 CEST pid=5175 WARNING:  terminating connection
 2011-10-04 09:48:37 CEST pid=5175 DETAIL:  The postmaster has
 2011-10-04 09:48:37 CEST pid=5175 HINT:  In a moment you should be
 2011-10-04 09:48:37 CEST pid=995 LOG:  all server processes
 terminated; reinitializing
 2011-10-04 09:48:38 CEST pid=5438 LOG:  database system was
 interrupted; last known up at 2011-10-04 09:32:41 CEST
 2011-10-04 09:48:38 CEST pid=5438 LOG:  database system was not
 properly shut down; automatic recovery in progress
 2011-10-04 09:48:38 CEST pid=5438 LOG:  record with zero length at
 0/201D9A8
 2011-10-04 09:48:38 CEST pid=5438 LOG:  redo is not required
 2011-10-04 09:48:38 CEST pid=5441 LOG:  autovacuum launcher started
 2011-10-04 09:48:38 CEST pid=995 LOG:  database system is ready to
 accept connections
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1227>
