[postgis-devel] [PostGIS] #1232: Exception when calling isValid on multilinestring with only 1 point
trac at osgeo.org
Mon Oct 10 01:05:56 PDT 2011
Reporter: hopfgartner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by hopfgartner):
I've compiled and installed GEOS 3.3.1:
[root at rpm-devel x86_64]# rpm -qa | grep geos
geos-3.3.1-2.el5
geos-php-3.3.1-2.el5
geos-devel-3.3.1-2.el5
I compiled PostgreSQL 1.5.3 and installed the postgis packages:
bash-3.2$ rpm -qa | grep postgis
postgis-1.5.3-3.el5
postgis-docs-1.5.3-1.el5.elgis
postgis-utils-1.5.3-3.el5
test1232=# select postgis_full_version();
POSTGIS="1.5.3" GEOS="3.3.1-CAPI-1.7.1" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.6.26" USE_STATS
I've loaded the data from the attached dump, but:
test1232=# select isvalid(the_geom) from geosbug;
NOTICE: IllegalArgumentException: point array must contain 0 or >1
elements
ERROR: Exception in LWGEOM2GEOS
Peter
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1232#comment:3>
