[postgis-devel] [PostGIS] #1232: Exception when calling isValid on multilinestring with only 1 point
PostGIS trac at osgeo.org
Sat Oct 8 11:15:08 PDT 2011
 Reporter:  hopfgartner  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 1.5.4
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Changes (by strk):
  * milestone:  PostGIS 2.0.0 => PostGIS 1.5.4
Comment:
 This bug was supposedly fixed with 1.5.3, as long as built against
 GEOS-3.3.0+ or 3.2.3+.
 I suggest you rebuild postgis from scratch and don't miss to source the
 postgis_upgrade_minor.sql or however it's called (see the procs..need
 upgrade message)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1232#comment:2>
