[postgis-devel] [PostGIS] #1181: topology.TopologySummary is broken
PostGIS trac at osgeo.org
Fri Sep 9 19:03:10 PDT 2011
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by robe):
 Here is the document that describes the structure --
 http://www.census.gov/geo/www/tiger/tgrshp2010/TGRSHP10SF1AA.pdf
 You'll notice that the edges, faces tables are very similar to our edge
 and face except diffeernt naming of columns.  The connecting nodes can be
 inferred from the node ids of tnidf, tnidt columns in the edges table and
 really all the features they provide are denomalized topogeoms from these
 tables I believe for normal GIS consumption.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1181#comment:7>
