[postgis-devel] [PostGIS] #1186: CreateTopoGeom I think is over-called in some cases and creates orphan relations
PostGIS trac at osgeo.org
Sat Sep 10 08:23:43 PDT 2011
relations
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 I had this query:
 INSERT INTO boston.roads(tlid, fullname, mtfcc, topo)
 SELECT DISTINCT ON (m.tlid) m.tlid, fullname, mtfcc,
         topology.CreateTopoGeom('topo_boston',
                         2,3, ('{{' || e.edge_id::text ||
 ',2}}')::topology.topoelementarray)
 FROM tiger_data.ma_edges AS m
                 INNER JOIN topo_boston.edge As e
                 ON m.tlid = e.edge_id
                 WHERE m.mtfcc LIKE 'S%';
 Which results in creation of 25075 records.
 However when I run summary:
 SELECT topology.TopologySummary('topo_boston');
 It gives me:
 Topology topo_boston (15), SRID 2249, precision 0.25
 20576 nodes, 31597 edges, 11109 faces, 25144 topogeoms in 1 layers
 Layer 3, type Lineal (2), 25144 topogeoms
  Deploy: boston.roads.topo
 I suspect the function is being called for every duplicate and not
 checking that the topo geometry is already registered in relations for
 that table.
 I had even more ridiculous answer of :
 topologysummary
 20576 nodes, 31597 edges, 11109 faces, 50288 topogeoms in 1 layers
 Layer 2, type Lineal (2), 50288 topogeoms Deploy: boston.roads.topo
 The first time I created my table and then cancelled the insert midway
 when I realized I was adding more than roads.
 This is on PostgreSQL 9.1 rc1 so not sure if its a PostgreSQL bug of
 topology bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1186>
