[postgis-devel] [PostGIS] #1158: Can't compile under Windows mingw
PostGIS trac at osgeo.org
Mon Sep 12 04:40:53 PDT 2011
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Robe, could you please try the attached file:pgcommon_as_object.patch with
 all your pgsql versions ? The patch only touched postgis module, not
 raster module, so you may be successfully in postgis and not in raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1158#comment:54>
