[postgis-devel] ST_IsValidReason causes crash
maplabs at light42.com maplabs at light42.com
Mon Sep 12 19:29:35 PDT 2011
Linux tone 2.6.32-5-amd64 #1 SMP Tue Jun 14 09:42:28 UTC 2011 x86_64 GNU/Linux
POSTGIS="2.0.0SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.8" USE_STATS
no crash
Linux aced 2.6.32-5-amd64 #1 SMP Tue Jun 14 09:42:28 UTC 2011 x86_64 GNU/Linux
POSTGIS="1.5.3" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September
no crash
On Tue, 13 Sep 2011 11:39:55 +0930, James Sewell  wrote:
Hello All,
  I am running the following version on both CentOS and Solaris 10:
    POSTGIS="1.5.3" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.6.26" USE_STATS
  The following SQL causes a crash on both:
     create table test (the_geom geometry);
     insert into test(the_geom) values
('0103000020BB100000010000000E0000002F2FC03E3A146240D5A76620E0AF42C075ED66A1381462401CCF6740BDAF42C0980B016538146240E39A4C26B8AF42C0A8CA5246371462407E6DFDF49FAF42C0819AB56F49146240EA63F492B5AF42C0E17A14AE471462401D9DA9C601B042C04AE18B404614624074F7EFB03FB042C0E0C8F2642D1462405305A3923AB042C06EC5596C2E146240B06EBC3B32B042C0B294D16D2E14624022B4D43032B042C080F43C6E2E1462405175502E32B042C07DF43C6E2E1462406375502E32B042C04754A86E2E146240A536CC2B32B042C02F2FC03E3A146240D5A76620E0AF42C0');
    select St_IsValidReason(the_geom) from test;
The first IsValidReason works as expected, then the second causes a
psql hang and I see the following in the logs (CentOS):
     *** glibc detected *** postgres: plm25 plm25 [local] SELECT:
free(): invalid next size (fast): 0x09a77228 ***
  Can anyone reproduce this? I can’t with my other install:
    POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August
2008" LIBXML="2.7.6" USE_STATS
  Any ideas on how I could further troubleshoot?
  Cheers,
  James Sewell
Solutions Architect
LISAsoft
        Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
  http://www.lisasoft.com
  The contents of this email are confidential and may be subject to
legal or professional privilege and copyright. No representation is
made that this email is free of viruses or other defects. If you have
received this communication in error, you may not copy or distribute
any part of it or otherwise disclose its contents to anyone. Please
advise the sender of your incorrect receipt of this correspondence.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110912/b31df8fc/attachment.html>
