[postgis-devel] ST_IsValidReason causes crash
James Sewell James.Sewell at lisasoft.com
Mon Sep 12 20:44:56 PDT 2011
Fixed with on upgrade to GEOS 3.3.0.
Cheers,
James Sewell
Solutions Architect
LISAsoft
Ph: +61 3 8680 3250 Fax: +61 3 8680 3299
Level 9, 601 Bourke St, Melbourne Vic 3000
http://www.lisasoft.com<http://www.lisasoft.com/>
From: maplabs at light42.com [mailto:maplabs at light42.com]
Sent: Tuesday, 13 September 2011 12:30 PM
To: postgis-devel at postgis.refractions.net; James Sewell
Subject: ST_IsValidReason causes crash
Linux tone 2.6.32-5-amd64 #1 SMP Tue Jun 14 09:42:28 UTC 2011 x86_64 GNU/Linux
POSTGIS="2.0.0SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS
no crash
Linux aced 2.6.32-5-amd64 #1 SMP Tue Jun 14 09:42:28 UTC 2011 x86_64 GNU/Linux
POSTGIS="1.5.3" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.7.8" USE_STATS
no crash
On Tue, 13 Sep 2011 11:39:55 +0930, James Sewell wrote:
Hello All,
I am running the following version on both CentOS and Solaris 10:
  POSTGIS="1.5.3" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September 2009" LIBXML="2.6.26" USE_STATS
The following SQL causes a crash on both:
   create table test (the_geom geometry);
   insert into test(the_geom) values    ('0103000020BB100000010000000E0000002F2FC03E3A146240D5A76620E0AF42C075ED66A1381462401CCF6740BDAF42C0980B016538146240E39A4C26B8AF42C0A8CA5246371462407E6DFDF49FAF42C0819AB56F49146240EA63F492B5AF42C0E17A14AE471462401D9DA9C601B042C04AE18B404614624074F7EFB03FB042C0E0C8F2642D1462405305A3923AB042C06EC5596C2E146240B06EBC3B32B042C0B294D16D2E14624022B4D43032B042C080F43C6E2E1462405175502E32B042C07DF43C6E2E1462406375502E32B042C04754A86E2E146240A536CC2B32B042C02F2FC03E3A146240D5A76620E0AF42C0');
  select St_IsValidReason(the_geom) from test;
The first IsValidReason works as expected, then the second causes a psql hang and I see the following in the logs (CentOS):
   *** glibc detected *** postgres: plm25 plm25 [local] SELECT: free(): invalid next size (fast): 0x09a77228 ***
Can anyone reproduce this? I can’t with my other install:
  POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August 2008" LIBXML="2.7.6" USE_STATS
Any ideas on how I could further troubleshoot?
Cheers,
James Sewell
Solutions Architect
LISAsoft
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel<http://webmail.light42.com/hwebmail/services/go.php?url=http%3A%2F%2Fpostgis.refractions.net%2Fmailman%2Flistinfo%2Fpostgis-devel>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110913/cea7f09b/attachment.html>
